1710 Ford!!
/ 1710 Ford!! #1
Fishman1227
Cassville
Ford 1710
I have a 1710 Ford tractor. I am getting ready to change the Hydraulic Oil tomorrow or the next day. Does it hurt to use an off brand oil, or should I stay with what Ford Dealer has to offer?? I'm still trying to get all the moisture out!
Thanks
Fishman1227
/ 1710 Ford!! #2
Do some research if you plan to use an oil that is not OEM. Make sure the oil meets the manufacturer's recommendation. We see a lot of hydraulic problems related to cheap "just as good" hy oil in our shop. Problems such as brake delamination, wet clutch failure due to heat, hy pump under performance, (low flow, low pressure, premature pump failure). Granted these are not scientific lab experiments but when you see problem after problem and tractor after tractor with hy issues and cheap box store oil you can't help blaming the oil. Heres a John Deere hy oil page to get you started on the research.
https://jdparts.deere.com/partsmkt/document/english/pmac/4968_fb_HyGardsTransmissionHydraulic.htm
/ 1710 Ford!! #3
X2. We have the same type problems in out part of the country. As stated above, do your research. Just because an oil meets OEM minimum specs, doesn't mean it is the same quality as OEM oil. Most, if not all, OEM's have additives blended in to help with the problems Harvey H mentioned. Not sure if the aftermarket oils include these additives.
Check out this page. I know it talks about the N series tractors, but it explains a little about hydraulic oils. Hydraulic/Transmission Fluid - The Full Story, by Llamas
Mike
1998 MP CUSTOMS PRESSURE WASHER TRAILER (A67714)
1998 MP CUSTOMS...
2011 FREIGHTLINER CASCADIA (INOPERABLE) (A67714)
2011 FREIGHTLINER...
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
Sullair 375 CFM Mobile Air Compressor (A68134)
Sullair 375 CFM...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
PILES OF TARPS (DIMENSIONS UNKNOWN) (A68842)
PILES OF TARPS...
