1705 wheel weights?
   / 1705 wheel weights? #1
Mattsy Fergy
Erie PA
GC1705
I do have the tires loaded, but I slid down a hill on wet grass, in 2wd recently, back tires locked up, loader on. So I started into looking at extra weight for the rear. The wheels have no holes for bolt on weights.
So I guess I'm looking at building a weight box for the 3pt hitch arms. I'm trying to avoid buying chains for winter, but will probably have to anyway.
How much weight is safe on the arms?
   / 1705 wheel weights? #2
I carry a 550lb 54inch Blizzard blower on the 3pt. I use a weight box in the summer for ballast with 450lbs in it.
   / 1705 wheel weights? #3
Use 4WD and you can have some front wheel braking... BUT you need rear ballast...
I just picked up 260 pounds of barbell weights for beginning of my ballast weight.. Looking for about another 260-300 lbs...
Was doing calculations for the DL 95 FEL and it worked out to be about (minimal) 600 pounds...That would be about 4 cubic feet of concrete
Dale
   / 1705 wheel weights? #4
I ALWAYS have something on the 3-point. About 90% of the time - Rhino 950 rear blade @ 1100#. OR the LPGS @800# or the chipper at 760#.
Plus I have 1550# of RimGuard in the rear tires.
How much weight can your lower arms on you 3-point system carry - check your owners manual or go to TractorData.com.
   / 1705 wheel weights? #5
Mine says the 3pt will lift 1190lbs..
OK, thanks guys. I was thinking 450-500 lbs would be good.
My buddy says "just eat a few more donuts"! :D:laughing:
   / 1705 wheel weights? #7
That's why I like the weight box, you can add and take weight from it pretty easy.
   / 1705 wheel weights? #8
Titan Attachments offers a nice weight box for a reasonable price. Apparently I do not meet the minimum post count to embed a link, but it's easy to find.
I have mine filled with solid concrete blocks from Home Depot, I would guess total weight somewhere around 5-600lb. It carries that with no problem and makes the tractor much more stable when moving heavy loads with the bucket.
Thanks, but I enjoy building things, and I'm too cheap to pay that much.
   / 1705 wheel weights? #10
Then make your own lead, steel and concrete wheel weights:
~250 lbs each.
40' CONTAINER (A51244)
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
BIG TEX T/A 16 TRASH TRAILER (A55745)
BIG TEX T/A 16...
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A55852)
2006 Ford F-650...
