3-Point Hitch 1705 stabilizer
   / 1705 stabilizer #12
Have a similar issue bent the living heck outta one of mine. No clue how, but regardless did you wind up buying at TSC?
Or do you have a source?
   / 1705 stabilizer
As a temporary solution I pieced together a turnbuckle, clevis, and pins from tsc. For a permanent solution I placed an order for a set from stabilworks. I highly recommend stabilworks!
   / 1705 stabilizer
I would post a picture but the ads are blocking that button for me I think
   / 1705 stabilizer
Downloaded app so I can attach pictures. First picture shows stabilworks installed and you can see a little bit of temporary turnbuckle on the ground. Second picture shows stabilworks by themselves. Third picture shows temporary turnbuckle clevis and pins installed. Hope that helps. 20191025_144529.jpeg20191018_162807.jpeg20190510_162806.jpeg
   / 1705 stabilizer #16
   / 1705 stabilizer
I don't have a backhoe so I've never tried to fold them up. I suspect they won't fold up quite as easy as the floppy turnbuckle clevis and pins but will defer to others with more experience.
   / 1705 stabilizer #18
Interesting, guess I need to go by TSC to get some that aren’t bent then order the stabilworks ones. Also I’ll take a look but I bet they will go ld fine.
   / 1705 stabilizer #19
Just put in my order. Stabilworks is currently backordered for 9 months. Yep told me I am in line expect an invoice spring of 2021..
   / 1705 stabilizer
Similar experience. I suspect he's a part time one man operation. Well worth the wait and also the reason for my cheap TSC temporary fix I pieced together.
Giyi Stump Bucket (A57149)
Giyi Stump Bucket...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 GPS GTT7167K 16ft T/A Utility Trailer (A56859)
2025 GPS GTT7167K...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
