17.5X24 R4 tire off rim
   / 17.5X24 R4 tire off rim #1
johnday2
Barton City Michigan, BFE
NH TC35DA
As thread title says. I got stupid and let my rear tires get too low on air, and spun one off the rim. I've got an idea on how to remount it with a 4" transport strap.
Is that the best way other than remove it and take to a shop?
Where is the best for floor jack placement on a TC35DA?
   / 17.5X24 R4 tire off rim #2
I did the same thing with one of my front tires. Used a ratchet strap around the center of the tread line to squeeze the beads out and used lots of air to reseat the beads. I would hate to have to do that on one of the rears. You could always try the starter fluid & match method. Be sure to take a video and post it here if you do.
LOL, no on that starter fluid thing!:eek: I didn't see it happen, but I saw the aftermath on a skidder tire. It does work though!
Yepper, it's gonna take a lot of air on that size tire.
For anyone following this saga. I stuck a 4" strap I used to use for transport on the tire, and was all set to put the air to it, when I discovered why I lost air in the tire, Evidently, a stick or something hit the fill valve and busted it. Since I live in BFE, the parts store is a good 30 miles away, and of course they were out of the valve I needed. So, another day, another trip!:rolleyes:
   / 17.5X24 R4 tire off rim #5
Jack the tractor up a bit, get a bead blaster and an engine powered air compressor (rental), after you replace the valve stem 10 minuets and you'll be good to go.
   / 17.5X24 R4 tire off rim #6
Ether works... But it's one of those things where less is better than more to begin with...
   / 17.5X24 R4 tire off rim #8
Sometimes it takes more than one strap...and silicone or soapy water doesnt hurt.
   / 17.5X24 R4 tire off rim #9
Put a tube in it. The problem with ether on that size tire is that it probably will stay mounted for a few seconds and when the hot blast cools down, it will suck itself off the rim again. But that depends on whether the rim has a safety flange at the bead. A tube never fails to rim the tire.
   / 17.5X24 R4 tire off rim #10
Put some liquid soap around bead area. Makes it work better. Do not use hand cleaner.
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
New 27ft Ratchet Strap (A54865)
New 27ft Ratchet...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
