civilian
Veteran Member
- Joined
- Oct 3, 2015
- Messages
- 2,172
- Location
- Vanderbilt, MI
- Tractor
- Gravely Pro 16 walk behind, Kubota BX2230, Kubota B26TLB
Following along to hear the end result. Good luck in getting it resolved properly. Jon
Here's an update. I called the dealer today and talked to their service department. They acknowledged the situation and said they've been doing it that way for many years and haven't had a problem. They said they use cone nuts on 9/16" studs and flange nuts for 5/8" studs all with the same wheel rims. (It looks like they took them off another trailer that had them mounted with flange nuts) At the end of the call they said that it is what it is, implying that they really don't care whether it's right or wrong. So, that now brings up 2 more questions 1) If I change to the flange nuts, will I have a problem with the wheel rotating on the hub since the holes are big enough for a 5/8" stud? 2) Do I have the right rim to use with cone nuts or do I need a different rim? or #3) does it really matter? I really don't want to be on the side of the road with a broken rim and 5 ton load.
Here's the latest as of today (Monday Nov 16, 2020).
I have the wheel rim info that says flanged nuts are required and cone nuts are the wrong ones from the spec sheet - post #6
I have an email from PJ Trailers saying that flange nuts are to be used on this style of wheel rim.
I have an email from Dexter axle saying that the 17.5" rim has to be the cone type to the 9/16" studs and the flat faced one is only to be used with 5/8" studs and flat faced lug nuts.
I have a 2nd email from PJ Trailers saying that the rim the dealer installed is the wrong one.
Looks pretty clear to me what the solution needs to be. I've sent these emails to the saleslady at the dealer along with the chart from rickson. She is going to talk to the manager to see what they're going to do.
I'll update this as things develop.
