Loader 16L FEL tilt cylinder problem. FEL "feet" split
   / 16L FEL tilt cylinder problem. FEL "feet" split #1
ccap74
Chickamauga,Ga
NH TC45DA
Last night, after a hard days work. I noticed that one side of the backing plate of my forks, on my FEL, came off. When I unlocked the attachment to re-attach forks, I noticed the "Foot" on one side was different than the other. I tilted the "Feet" up and the left side came up and stopped before the right side. Help?
   / 16L FEL tilt cylinder problem. FEL "feet" split #2
The hydraulic cylinder with the least friction will retract/extend before the other. The torque tube that broke makes sure they operate the same by locking them together. When one cylinder reaches its limit, the other cylinder should move. Fix the torque tube and the problem will correct itself.
Where is this torque tube, Jinman?
   / 16L FEL tilt cylinder problem. FEL "feet" split #4
It's what runs between the left and right paddle. It may not be broken, but probably bent/twisted when one paddle came loose.
Thank you.
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
527 (A52708)
527 (A52708)
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
Dewalt D28755 14" Cut-Off Machine (A59076)
Dewalt D28755 14"...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
