Loader 16L FEL tilt cylinder problem. FEL "feet" split
   / 16L FEL tilt cylinder problem. FEL "feet" split #1
ccap74
Chickamauga,Ga
NH TC45DA
Last night, after a hard days work. I noticed that one side of the backing plate of my forks, on my FEL, came off. When I unlocked the attachment to re-attach forks, I noticed the "Foot" on one side was different than the other. I tilted the "Feet" up and the left side came up and stopped before the right side. Help?
   / 16L FEL tilt cylinder problem. FEL "feet" split #2
The hydraulic cylinder with the least friction will retract/extend before the other. The torque tube that broke makes sure they operate the same by locking them together. When one cylinder reaches its limit, the other cylinder should move. Fix the torque tube and the problem will correct itself.
Where is this torque tube, Jinman?
   / 16L FEL tilt cylinder problem. FEL "feet" split #4
It's what runs between the left and right paddle. It may not be broken, but probably bent/twisted when one paddle came loose.
Thank you.
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
2022 Ford F-750 Super Duty Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A49461)
2022 Ford F-750...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A49461)
2011 Kenworth T300...
Allis Chalmers Disk (A50515)
Allis Chalmers...
