16hp cast iron Briggs Model 326437 sump gasket
   / 16hp cast iron Briggs Model 326437 sump gasket #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I have a wards garden tractor with a 16hp Briggs that needs some love.
The engine sump is part of the tractor frame.
I removed the engine from the sump and noticed there was no gasket.
Is the gasket preferred or just sealant?
I ordered all new gaskets & seals looking for an informed opinion.
90cummins
   / 16hp cast iron Briggs Model 326437 sump gasket #2
Some manufactures just use sealant instead of a gasket ....I use what it came with or both........
   / 16hp cast iron Briggs Model 326437 sump gasket #3
If the gasket set has the gasket in it---use it but also use sealant on it. ---doubles your chance of getting it sealed up good.
   / 16hp cast iron Briggs Model 326437 sump gasket #4
One would assume then it had been apart and the person used sealant instead of the gasket. Were the fasteners tight? I would be concerned if they weren't secure and take extra steps to lock them in.
Not particularly tight.
Being almost 50 years old it痴 hard to imagine it never being removed for some reason.
I致e always been intrigued with these big singles and wanted one.
90cummins
The gasket will be used along with some sealant.
90cummins
72" Hydraulic Broom  (A52384)
72" Hydraulic...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
Versatile 500 (A53342)
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
