16hp cast iron Briggs Model 326437 sump gasket
   / 16hp cast iron Briggs Model 326437 sump gasket #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I have a wards garden tractor with a 16hp Briggs that needs some love.
The engine sump is part of the tractor frame.
I removed the engine from the sump and noticed there was no gasket.
Is the gasket preferred or just sealant?
I ordered all new gaskets & seals looking for an informed opinion.
90cummins
   / 16hp cast iron Briggs Model 326437 sump gasket #2
Some manufactures just use sealant instead of a gasket ....I use what it came with or both........
   / 16hp cast iron Briggs Model 326437 sump gasket #3
If the gasket set has the gasket in it---use it but also use sealant on it. ---doubles your chance of getting it sealed up good.
   / 16hp cast iron Briggs Model 326437 sump gasket #4
One would assume then it had been apart and the person used sealant instead of the gasket. Were the fasteners tight? I would be concerned if they weren't secure and take extra steps to lock them in.
Not particularly tight.
Being almost 50 years old it痴 hard to imagine it never being removed for some reason.
I致e always been intrigued with these big singles and wanted one.
90cummins
The gasket will be used along with some sealant.
90cummins
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
1997 GROVE TMS750B 50 TON CRANE (A51222)
1997 GROVE TMS750B...
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
