165 lift arms not responding right
/ 165 lift arms not responding right #1
joe17
kerry
massey ferguson 165
my Massey 165 lift arms not responding right when i go to lift a plough it does not respond right away some times i have to put in gear and it lifts but takes a while to do so then when i what to lower the lift arms it drops down very fast is it my Hydraulic Lift Cylinder or what
/ 165 lift arms not responding right #2
Sounds like three point hydraulic pump is getting weak, will need to check relief pressure, may need pump repair, or have leaking standpipe o rings only if you are lucky.
/ 165 lift arms not responding right #3
Contaminated fluid (moisture from deteriorated shift lever boots or excessive grease from lift arms) and/or dirty filter, standpipe o-rings or tired hyd pump. Start with the easy stuff first, boots / o-rings and filter inexpensive and hyd fluid for mine was around $200 if I remember correctly. Mine worked like new afterwards.
