1641 Noise... Help
/ 1641 Noise... Help #1
bobferdon
Last season my PTO locked up, ripped out my wiring harness and the torque plate. I just put it back together this weekend.
Fired it up and put it into gear and there is a loud racket that sounds like bb's in a blender. :mad:
It goes into gear and seems to move. It is up on jack stands.
Any thoughts on what this noise might be?
Thanks...
/ 1641 Noise... Help #2
My first thought would be to double check the PTO adjustments. You should have .020-.025 clearance between the disk and rotor all the way around when disengaged. Does it sound the same engaged or disengaged? Does it disengage correctly?
Bob B.
I just put a new PTO on it. It did it with the last PTO on it also.
It only does it when I disengage the brake and start to move. Sometimes it will do it when idling with the brake off. As soon as I come up to speed it goes away.
/ 1641 Noise... Help #4
the topic is where i am today, on my 3184 it has a bellows that puts pressure on the 2 pto belts but I have a problem the front belt comes off the double pulley.i removed the heat shield and the top belt guard to get at the the belts, i removed the front belt from the pulley and all is well I just need to know a remedy on keeping the front belt from getting thrown off and chewed up or should I just keep cutting using the rear pulley groved belt?
thanks all Wayne ars N4VGY
