1610d won't go,help
/ 1610d won't go,help #1
dbloyd
i live on a mini farm 25 acres in mcnairy co. tn.
1949 allis chalmers model c and yanmar 1610d.
iam a new member and i have a ? my tractor is a 1610d with the shuttle
shift. lately it has been very slow or relutant to begin moving after cranking
and putting it in gear. what could be wrong?
/ 1610d won't go,help #2
How long have you had it? Have you checked the hydraulic fluid level in the transmission? If that level is good you may need to pull the screen (filter) and check it for debris. They can get clogged and prevent flow which makes the tractor slow to go into gear.
If all that is good to go, then you might need to check the flow from the pump.
Box
/ 1610d won't go,help #3
If the suction screen is clean, check your relief valve springs.
/ 1610d won't go,help #4
The suction screen is the most likely culprit. After that ,relief valves and their components. Powershifts don't die, they must be killed.
/ 1610d won't go,help #5
Like has been said. Clean the screen .. Re fill with clean jd 303 or equivalent. Some use ATF in their power shifts
/ 1610d won't go,help #6
It has not been mentioned, but be sure to drain the Transmission before trying to clean the
filter. I think it contains about 3 1/2 or 4 gals. of oil
Gary
/ 1610d won't go,help #7
To slightly side-track, If you are going to change the trans fluid on a tractor which needs a change REALLY BAD, should it be flushed somehow?
thanks for all your responses. i have had this tractor for 4 years. i got it from
a guy in memphis that got it at tulahoma tractors. how do i get to this screen and the releif valves.
/ 1610d won't go,help #9
Hoye Tractor Parts
Parker Equipment =1danny
and others
oil changes and cleaning the screen are basically flushing the system. removing the draw bar plate and wiping the settled sediments in the lower casing clean would be one step further to a better cleaning. trying a flush chemical is not suggested, just change oil and keep the screen clean more frequent.
/ 1610d won't go,help #11
Follow the large hydraulic suction line to the rear of the transmission. There is a 3 bolt flange on the end of that steel line. Remove the flange and line (after draining the hydraulic fluid) and you will see the internal screen.
/ 1610d won't go,help #13
Have you checked with Hoye to see if they have a manual for your model. They had one for my FX26D and it is a big help. Good luck - I am having head problems so I can empathize with your situation.
no, i don't have a manual but i would like to have one. iam starting my
retirement on nov. 19, so i will probably start doing all my own maintannce.
UNUSED WOLVERINE RSB78-78" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
1043 (A60430)
1043 (A60430)
Challenger MT400 and MT600 series tractor parts manuals (A63117)
Challenger MT400...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2014 Mitsubishi Outlander Sport SUV (A61574)
2014 Mitsubishi...
Caterpillar 966G/972G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
