1610D head gasket
   / 1610D head gasket #1
kenr74
Amity, OR
Yanmar 1610D
I think I'm in need of a head gasket but wanted to confirm.
Runs/starts great but quickly overheats and pukes coolant. I put a bottle on the overflow hose and am getting lots of air bubbles. No coolant in the oil though. I just installed a new radiator cap to make sure that wasn't the issue but no change.
Sounds like a head gasket to me but any other ideas?
   / 1610D head gasket #2
I agree with your assessment.
   / 1610D head gasket #3
One more comment - if you suspect compression is getting into the cooling system then there is a chance there could be water in a cylinder the next time you start it. So crank with the compression released for a few revolutions, to flush out any water, before starting it.
   / 1610D head gasket #4
Auto parts will rent or Borrow one. Radiator Pressure test Just attach it with the correct cap and see how much pressure the radiator does have in it. Should be around 13-16 PSI. your checking the pressure build up from a bad Gasket,Warped Head, Crack in Head/Block Etc.. real easy to Chk.. Harbour frieght, Walmart has kits cheap!!
   / 1610D head gasket
Thank you. It will be a while before I can dig into this but sounds like I have some work to do.
John Deere 410C Backhoe (A49251)
John Deere 410C...
1999 International 4700 Flatbed Truck w/Title (A49251)
1999 International...
2024 Kubota RTV-X1100C Utility Cart (A46684)
2024 Kubota...
2016 Ford Escape SUV (A46684)
2016 Ford Escape...
Pallet Fork Backing/Spear/Reese Hitch Combo (A47371)
Pallet Fork...
More info coming soon! (A48082)
More info coming...
