1610 Question
/ 1610 Question #1
mdbender
Southern Maryland
Yanmar 1610
As a newbie tractor owner I really am impressed with my 1610 with FEL and rear scraper blade. Already spread 30 yds of compro on the front yard/cleared and graded back yard and extended driveway. Question is stowing my 3 pt hitch. When I raise the lever the blade drops right down. The only way that I can get it to stay up is to close the valve under the seat or adjust height setting stop ( screw and bushing with wingnut )on lever tract. Is this correct operation. I read in another post that if you close the valve under the seat and try to raise 3 pt you can shear a pin in the pump. Is there a adjustment that can be made to increase the friction on this lever to allow the hitch to stay up without doing any of this?
/ 1610 Question
/ 1610 Question #3
You should never leave or stow the 3ph in the raised position; however, it should remain in the raised position for a given period of time before bleeding off.
/ 1610 Question #4
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
2000 Volvo Semi Truck (A66285)
2000 Volvo Semi...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
100 Gallon Galvanized Water Tank (A65579)
100 Gallon...
