1602d three point lower - upper support
/ 1602d three point lower - upper support #1
luky69
italy
1602D - 2210D
I all,
i'm Gianluca from Italy, this is my yanmar 1602d with new support for three poin, what do you think?
/ 1602d three point lower - upper support #2
Gianluca - greetings & welcome to TBN!
Very nice! They look like factory made - did you fabricate them?
My only suggestion is to maybe add a bushing on each of the lower pins to prevent the arms from sliding left or right.
This would give you more stable support of your implement.
If you locate the bushing between the Heim fitting and the lynch pin, it will also reduce bending load on the pins.
Ciao,
Jim
Thanks for reply Jim, yes i drawn this pieces and cut by the laser machine! the lower pin is welded to the plate thickness 10mm and is inside the tractor case about 15mm, with this sistem i lift 250kg without any bend!! i agrre with you about the bushing to reduce the play :thumbsup:
Thanks, and lateral plate for the chain is work in progress Tirante laterale.jpg
/ 1602d three point lower - upper support #7
You, sir, are a true craftsman. Are you an engineer by trade?
thanks, i'm a mechanical designer, and my hobby is the little tractor!
/ 1602d three point lower - upper support #9
Great designs, luky! Thanks for posting!
new drawbar telescopic!
/ 1602d three point lower - upper support #11
I must question why you are fabricating readily-available salvage parts.
thanks :thumbsup:
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2018 Ford F-150 4X4 (A62679)
2018 Ford F-150...
2022 EZ-GO ELITE...
60in. Skid Steer Bucket (A65640)
60in. Skid Steer...
