1601 Throttle
/ 1601 Throttle #1
turboblue46
I have a problem with my hand throttle. I pull it back to the engine speed that I want. But just soon as I let go of it. It creeps back down to a slow idle. It doesn't die but it comes close sometimes. Is there a adjustment on this thing somewhere to stop this. Thanks Mike
/ 1601 Throttle #2
Yes there is an adjustment, where it comes out the side.
First pull off the cover in front of the shifter off,the one below the key.
Then look inside the dash, on the right hand side you will see where the lever comes thru, I think it takes a 17mm or ??
just tighten it up a bit, not a lot or it wont move,and squirt some oil on it.
Replace the cover & enjoy !
Ernie
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
John Deere 6200 Tractor (A64047)
John Deere 6200...
CASE INTERNATIONAL 2208 - 8R30" CORN HEAD (A63291)
CASE INTERNATIONAL...
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
