16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan
   / 16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan #1
landrand
Ishpeming, MI
Internation 674, John Deer 6400, Kubota BX2670, Ford New Holland 655D
Last week I bought a 1998 John Deere 5410 tractor (MFWD Front) for my homestead here in Northern Michigan. The tractor is in really nice shape, but I'm a bit concerned about the existing tire's traction in sandy soil and the snow we get here during the winter. The tractor has rear 16.9 x 30 R-1 tractor tires on Titan-USA 30xDW14 8 position adjustable rims and front 11.2-24 on Titan-USA 24xW10 adjustable rim. The tires are Firestone's Tractor Field & Road Bias ply and they are original. Although the tires are in decent shape, I'm a bit concerned about their traction in my area. Yesterday, I used the tractor to move some round hay bales and do a little front end loader work, and a few times I noticed the tire's traction was not the best. I have areas that are 100% sand and the tires occasionally did spin in the sandy soil. I'm also a bit concerned about the tires when used during the winter. I'd be using the tractor to plow/clear snow on an 1.5 acre corral for my cows.
I local is selling a set of relatively new (50 hours) Firestone Performer 85 radial 18.4 x 30 R-1W rear tires and 12.2 x 24 fronts and I'm thinking of buying and using on my tractor. It appears I would be able to use the 12.2 x 24 tires on my existing 24 x W10 front rims, but I would need to find and buy rear 15" or 16" rims for the wider 18.2 x 30 rear tires. My research indicates that the existing 14" wide rims is not ideally suited for the wider tires.
Was wondering what the guru's think about migrating to wider radial tires? It's going to cost me a couple thousand dollars, and the time to find wider rear rims, so I would like to have some idea if it would be worth it. I've never used a large tractor with R-1/R-1W tires in the snow so any input or recommendations would be appreciated.
   / 16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan #2
Tires look fine to me. One thing to keep in mind if you do change them is the 'lead-lag' ratio in as much as it's FWA. You must stay in the proper ratio or you'll destroy the front drive axle. If you have an owners manual or if you contact a dealer, they will explain the 'lead-lag' ratio to you.
Yes, I found info about the lead-lag issue you are talking about. My manual says I can use 18.4-30 and 12.2-30 on my tractor, but I want to do the calculations as well. I have the vin numbers and other info for my front axle and transmission as well as the Firestone tire specs. Thanks for the info!
   / 16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan #4
Did the tractor have an implement on the back when you observed the slippage in the sand while loading the bucket?
It doesn't take much weight in the bucket to displace a little sand bareback. I'd save the bigger tires money and get some tire chains for the snow clearing and hang something heavy on the 3pt for the sand.👍
The tractor only had a 3 point hitch empty bale spear on the back. I have a box blade, maybe I'll put that on the back and see how well it does with some weight on the back.
   / 16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan #6
When I did round bale work for our horses I had one on the 3PT for ballast and moved the ones I needed the FEL. Then I dropped the one off the 3PT hitch for the last bale I needed to feed. Made it feel a whole lot more stable.
   / 16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan #7
You should be able to purchase cast weights for the rear rims. What I run on my Kubota's. They each weigh about 700 pounds each.
I might add that I rarely have anything on the back end when loading or transporting big rounds as the cast weights provide enough 'ballast' and I don't load tires either. I do have a 3 point hitch bale spear however so when I'm 'marshalling rounds in the fields, I'll stab a round on the rear spear and on the front spear as well and collect them that way, makes for a faster collection. Have a hitch ball welded to the top of the rear spear so I can tote around the GN trailer as well. Saves cranking the landing gear up and down, I just pick up the GN until the landing pads clear and go about my business.
   / 16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan #8
Like I said in JD forum I have no problems with R1's in snow and would have the rears loaded or buy chains instead of another set of tires
   / 16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan #9
If your unit is FWA, traction on any surface should not be an issue, I don't follow your reasoning. If it's not, then I can understand. For what I do, R1's are the only tires I'd run.
   / 16.9-30 vs 18.4-30 Tire for JD 5410 Tractor in N. Michigan #10
When lifting moving heavy weight with the front end loader (bucket or forks) make sure your front axle is engaged. That's what I have to do with my Kubota or the rear tires just spin. If whatever you lift is so heavy the rear tires are coming off the ground then put something heavy on the 3 point hitch.
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
2017 Ford F-350 4x4 Crew Cab Flatbed Service Truck (A52377)
2017 Ford F-350...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
