16.5 briggs
   / 16.5 briggs #1
truckdriver23us
minnesota
craftsman 52700
runs smooth if choke is not open all the way . but surges when choke is open .adj. carb dont seem to do anything. any ideas? thx e1 .
   / 16.5 briggs #2
Check base of carb for looseness or bad gasket which will cause a vacuum leak. Also, condition of fuel (water in tank, dirty filters)
   / 16.5 briggs #4
Sounds like there is probably some crap in the main jet of the carb -- take it off - get a gasket set and clean it out. Usually when a Briggs runs ok with the choke on but not with it off the carb is the problem -- JMHO
   / 16.5 briggs #5
Stop by NAPA and get a can of carb cleaner.Dissassemble the carb completely removing all plastic and rubber parts.Pick up a carb rebuild kit from your local small engine shop.These parts are specific to your engines Model#Type# and code #s be sure you have all the #s.I use acetelene torch tip cleaners to carefully clean out all the crud that tends to build up in passages and jets in the carb.You can also use the wire in a bread sack tie.Blow out thouroughly with compressed air.Install a new in-line fuel filter,this should remedy your problems.Best of Luck:thumbsup:
Scotty
(4) 5 LUG WHEELS & TIRES (A51248)
(4) 5 LUG WHEELS &...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2001 John Deere M665 (A50120)
2001 John Deere...
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
2018 WACKER NEUSON EZ36 EXCAVATOR (A51246)
2018 WACKER NEUSON...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
