Thanks for the reply. So would my 15-40 compare more like AW46 (from the 15 ) or be more like the AW150 ( from the 40)?
I am running a hydraulic motor off of my skid steer and it leaks slowly around the seal once the hydraulic temperature gets over 150 degrees or so. It does not leak when cooler than that. I was thinking maybe the oil was too thin?
You may be on the right track here. I remember once in Canada I decided to change the oil in my motorcycle to put in 10W40. I cranked it up and let it warm up to drain the oil which did ok, but when I started to refill it (it was about -30F) it was like pouring really cold honey. I had to take the oil inside and heat it up in boiling water to be able to get it into the crankcase. It just puddled up at the fill port and took forever to creep down, nothing like I thought 10W or even 90W oil should be.The 15 in 15W40 does not stand for "15 weight". Think of the W as if it stood for "winter". The 15 and 40 have no direct relationship. It's a 40 weight oil that has a cranking resistance (not viscosity) of 15 based off a specific test standard for cranking resistance. Either way, it's a 40wt oil at 212*F, and is thicker than that at colder temps, but offers less cranking resistance than a straight 40wt would normally.
I work with a piece of machinery that uses a hydraulic cushion in a cylinder. To get that cushion to perform properly, a predecessor of mine specked a multi vis ISO 15 with a huge viscocity index... which not only was it too thin for the pump right from the get-go in the warmer months, it was quickly getting sheared down to around an ISO 9! Needless to say, I quickly had to learn more than I ever wanted to know about oil viscosity and hydraulic cushions. now that I have thicker oil working with the hydraulic cushion, I am having trouble with thick fluid, cold temperatures tripping velocity fuses. I am starting to realize why the last guy developed ulcers.
If you want to find what oils are acceptable to use, you have to know what working viscountcies the components like (usually pump and motor driven) and what temperature range you are running in the field. Basically, you have to make sure the viscosity isn't too high at start-up, and isn't too low at peak temperatures. you might even find some viscosity to efficiency charts for the pump to get the most out of your equipment.
Another thing to consider; I have heard that engine oil uses better base stock than hydraulic oil and resists wear better. I'm not so sure how true that is any more, but it wouldn't surprise me.
That's another TBN post that flies opposite current accepted tech norm...
