15w40 viscosity comparison to AW
/ 15w40 viscosity comparison to AW #1
bdog
Elite Member
Texas
John Deere 6130M
My skid steer specs 15-40 engine oil for the hydraulic fluid. How does this compare viscosity wise to regular hydraulic oils like aw32, aw46, or aw68?
/ 15w40 viscosity comparison to AW #3
AW 32 is similar in grade to SAE 10
AW 46 is similar in grade to SAE 15 - 20
AW 68 is similar in grade to SAE 20 - 25
Engine oils are NOT similar in composition or additive packages to AW hydraulic oils.
Thanks for the reply. So would my 15-40 compare more like AW46 (from the 15 ) or be more like the AW150 ( from the 40)?
I am running a hydraulic motor off of my skid steer and it leaks slowly around the seal once the hydraulic temperature gets over 150 degrees or so. It does not leak when cooler than that. I was thinking maybe the oil was too thin?
/ 15w40 viscosity comparison to AW #5
Terramite specs 15W-40 motor oil for their hydraulics. Engine oils are 'weight' tested at 212^ F to rate the second number, so 150^ sure doesn't sound too hot compared to what must be expected. Seems what works when under warranty also should afterward. btw: Engine oils are spec'ed for a 'reserve alkalinity' to inhibit corrosion ("TBN" #, .. does 'hydro' spec that?), so that or certain additives could be desired by the makers. I like the easy flow when cold (vs the NH's hydro :mur:) and the confidence of 40wt in my cyls on hot & dirty jobs.
This is 40wt leaking at temp, (not say AW68 or '??') tho' it seems they could be cross-compared. If not matching the spec too closely I wonder whether leaks might become worse? If it's already money on the ground, could that motor just be asking for a seal kit .. er, assuming you can spare the downtime?
/ 15w40 viscosity comparison to AW #6
Pretty much what he said , my understanding of multigrade oils is that they have the characteristics of the low number when cold and the high number when hot. I'd say it's time for a seal and leave the oil alone.
Sean
/ 15w40 viscosity comparison to AW #7
The 15 in 15W40 does not stand for "15 weight". Think of the W as if it stood for "winter". The 15 and 40 have no direct relationship. It's a 40 weight oil that has a cranking resistance (not viscosity) of 15 based off a specific test standard for cranking resistance. Either way, it's a 40wt oil at 212*F, and is thicker than that at colder temps, but offers less cranking resistance than a straight 40wt would normally.
/ 15w40 viscosity comparison to AW #8
You may be on the right track here. I remember once in Canada I decided to change the oil in my motorcycle to put in 10W40. I cranked it up and let it warm up to drain the oil which did ok, but when I started to refill it (it was about -30F) it was like pouring really cold honey. I had to take the oil inside and heat it up in boiling water to be able to get it into the crankcase. It just puddled up at the fill port and took forever to creep down, nothing like I thought 10W or even 90W oil should be.
/ 15w40 viscosity comparison to AW #9
Thank you Bart . I have argued this with a local brain surgeon . I will show Einstein this post .
/ 15w40 viscosity comparison to AW #10
Viscosity Charts - Bob is the Oil Guy
I will add that our Power-Tracs which have three pumps and four wheel motors, and 5 cyl have been using motor oil in the hyd systems for about 20 plus years. 10W-30, and 10W-40.
As far as I know, there have not been any failures attributed to the motor oil. Some of the Power-Trac owners are using the synthetic motor oils in the hyd systems.
Some of the Case equipment use motor oil with Case additives, and other Case machines use ATF, and others use Hy-trans hyd fluid.
The additives in motor are different that normal hyd fluid, but seem to work especially in heat tolerant.
2014 BMW 28I AWD SUV (A61569)
2014 BMW 28I AWD...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
IRanch REV High End Scooter (A60463)
IRanch REV High...
2010 John Deere 4720 (A60462)
2010 John Deere...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
