155d hydraulic Question
   / 155d hydraulic Question #1
gary1611
Bronze Member
I have a Front plow Which i currently use a winch to lift because the dealer could not find the hydraulics. I want to make it lift with hydraulics. <font color="red"> Is there a Port that i can hook a hose into to control it with the three point control. </font> Or maybe somebody here has the parts to do it right i'd like down pressure but don't want to do to much fabricating right know. When i build a loader i'll control it with that valve but for know i just want to control it with three point.
   / 155d hydraulic Question #2
Gary,
I think you will need a single controller regardless. You will have to tap into the pressure line on the bottom of your pump (small diameter line), run it to a single controller. like a log splitter controller for example, and to your implement and back to the high pressure side of the tractors hydraulics. I know of no other way to do it.
   / 155d hydraulic Question #3
You can use the 3 point control valve , but it will not have down pressure because the 3 point control valve is a single acting valve. You'll have to do like Mark said for a dual acting cylinder.
I understand that there is no down pressure with three point. was just asking if someone might have origanal plow hydraulic parts.
Can i just hook the into the port under the seat and to the rear of the tractor for up pressure. thankyou
For those that may use this post in the future for reference. My answer is yes.
its a port under and to the front of the seat. Its inline with the 3pt stop valve. There is a port on either side i will try to update when i get it completed. Thankyou to those that replied even the ones who pmed me.
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
2024 Dig Master DM-F20 Electric Fork Lift, NEW! (A52384)
2024 Dig Master...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
2019 Komatsu D51PXi-24 Crawler Tractor Dozer (A51691)
2019 Komatsu...
2009 Kubota RTV1140 (A50123)
2009 Kubota...
