1533 vs 1538
/ 1533 vs 1538 #1
Bungiex88
Dysart
73 Farmall 574, 2016 mahindra 1533
Was wondering if anyone knew what they de rated between these 2 tractors. It's the same engine with same rpm vs hp. Does anyone know if the timing is different, or programed different or what is it.
/ 1533 vs 1538 #2
Programmed different by the dealer. No other difference with regards to the motor or chassis. The tires on the 1538 are bigger.
To date I haven't seen anyone who has been able to change the programming.
/ 1533 vs 1538 #3
I was wondering about if it was possible to change 1533 to 1538 with a program.
/ 1533 vs 1538 #4
Nope wont be able to change the programing.
/ 1533 vs 1538 #5
Maybe programmed different by the factory but not by the dealer. My guess is that if you mess with it you'll be throwing your warranty out the window.
/ 1533 vs 1538 #6
Im betting will be more into it than just warranty... wouldn't be able to change it either way.
/ 1533 vs 1538 #7
Good catch! Factory installs the initial HP tune. Dealer can't/won't change the HP. They can install updated programming at the direction of Mahindra. I asked the dealer about changing HP when I got mine.
