1533 vs 1538
/ 1533 vs 1538 #1
Bungiex88
Member
Dysart
73 Farmall 574, 2016 mahindra 1533
Was wondering if anyone knew what they de rated between these 2 tractors. It's the same engine with same rpm vs hp. Does anyone know if the timing is different, or programed different or what is it.
/ 1533 vs 1538 #2
Programmed different by the dealer. No other difference with regards to the motor or chassis. The tires on the 1538 are bigger.
To date I haven't seen anyone who has been able to change the programming.
/ 1533 vs 1538 #3
I was wondering about if it was possible to change 1533 to 1538 with a program.
/ 1533 vs 1538 #4
Nope wont be able to change the programing.
/ 1533 vs 1538 #5
Maybe programmed different by the factory but not by the dealer. My guess is that if you mess with it you'll be throwing your warranty out the window.
/ 1533 vs 1538 #6
Im betting will be more into it than just warranty... wouldn't be able to change it either way.
/ 1533 vs 1538 #7
Good catch! Factory installs the initial HP tune. Dealer can't/won't change the HP. They can install updated programming at the direction of Mahindra. I asked the dealer about changing HP when I got mine.
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2016 Chevrolet Tahoe SUV (A60352)
2016 Chevrolet...
832788 (A61166)
832788 (A61166)
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
