1533 vs 1538
/ 1533 vs 1538 #1
Bungiex88
Member
Dysart
73 Farmall 574, 2016 mahindra 1533
Was wondering if anyone knew what they de rated between these 2 tractors. It's the same engine with same rpm vs hp. Does anyone know if the timing is different, or programed different or what is it.
/ 1533 vs 1538 #2
Programmed different by the dealer. No other difference with regards to the motor or chassis. The tires on the 1538 are bigger.
To date I haven't seen anyone who has been able to change the programming.
/ 1533 vs 1538 #3
I was wondering about if it was possible to change 1533 to 1538 with a program.
/ 1533 vs 1538 #4
Nope wont be able to change the programing.
/ 1533 vs 1538 #5
Maybe programmed different by the factory but not by the dealer. My guess is that if you mess with it you'll be throwing your warranty out the window.
/ 1533 vs 1538 #6
Im betting will be more into it than just warranty... wouldn't be able to change it either way.
/ 1533 vs 1538 #7
Good catch! Factory installs the initial HP tune. Dealer can't/won't change the HP. They can install updated programming at the direction of Mahindra. I asked the dealer about changing HP when I got mine.
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
2014 MERCEDES 2500 CARGO VAN (A59908)
2014 MERCEDES 2500...
New/Unused Landhonor Quick Attach Receiver Hitch (A61166)
New/Unused...
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A60736)
2019 INTERNATIONAL...
