1533 Brake Pivot Grease Fitting
/ 1533 Brake Pivot Grease Fitting #1
Sap Masta
Guilford, Maine
Massey Ferguson 1533
I am having difficulty locating the "brake pivot" grease fittings (2) on my 2007 1533. Any help would be appreciated. Thanks
/ 1533 Brake Pivot Grease Fitting #2
the fitting should be located on the underside of the platform on the end of the shaft that the brake petel makes the connectionn to linkage thats where
mine was on the 06 model
/ 1533 Brake Pivot Grease Fitting #3
try AGCO Parts Books you can get the exploded parts and assembly there, you would be suprised at what you can find there on your tractor
Thanks for the AGCO Parts Book tip. The fittings were located under the rubber floor mat - remove part of the mat to get to them.
/ 1533 Brake Pivot Grease Fitting #5
glad you found it. I do believe that the grease fittings locations should be listed better in the manuel, better than they do.
david
