1532 Rear Remote Install W/ Pics
   / 1532 Rear Remote Install W/ Pics #1
kabong57
Wenona,IL
8260 NH, 1532MF, YM2000 Yanmar, 930 Case,
Decided to go ahead and install the factory rear remotes on my 1532. It has factory fender mounted joystick loader valve.(Pic 1)
The new valves mount on the rear-end cover, right side. (Pics 2 & 4)
Remove bypass cover & sandwich valve bodies between it and rear housing.(Pics 5,7,9,11)
Valves mounted,lever pivots installed.(Pics 13 & 15)
Hope to finish tomorrow. Big Thank You to Jack's Small Engine for quick shipping and great pricing on MF parts. Steve
MF1532 009 (Small).jpg MF1532 007 (Small).jpg MF1532 005 (Small).jpg MF1532 004 (Small).jpg MF1532 002 (Small).jpg MF1532 001 (Small).jpg MF1532 011 (Small).jpg MF1532 013 (Small).jpg MF1532 015 (Small).jpg
Sorry guys, I could use a little help to put a space between pics and edit the order that they are shown. Steve
Re: 1532 Rear Remote Install W/ Pics Finished
Finished the install today. Pic of lower levers installed.
Upper levers installed.
Rear outlets.
Both valves do have a working "float" position. Each valve also has a small lever on the rear of the valve body to select single or double acting cylinder use. If you look real close in this picture you can see the rollpin lever.
   / 1532 Rear Remote Install W/ Pics #4
Looks good. :thumbsup: Did you order the valves with the float position, or did they just come that way? :cool:
These are the OEM valves direct from MF.
   / 1532 Rear Remote Install W/ Pics #6
I understand that they are the OEM valves. What I was wondering was did you have any options with the valves, or they only offer them set up as you have them with the float position?
Only valve they had in the parts listing so no it is not " an option", just comes standard .
   / 1532 Rear Remote Install W/ Pics #9
What do you figure will your primary use for the remotes?
   / 1532 Rear Remote Install W/ Pics #10
What do you have in this project dollars wise (if you don't mind me asking)? I've been contemplating on doing this as well and want the factory look like yours but just am not sure if I want to sink the money into right now.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
2007 VOLVO VHD64 TRI AXLE DUMP TRUCK (A53426)
2007 VOLVO VHD64...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
