1528
   / 1528 #1
IHPlowjockey
Recently ordered a 1528 gear drive with FEL, is there any options I should consider on this before I take delivery? Are they good starting in cold weather? Looking forward to my new purchase. It will be replacing a older Kubota.
   / 1528 #2
If you are getting a front end loader, definately get fluid or wheel wieghts for the rear tires. If you live in a cold weather climate, a block heater is always a good idea.
   / 1528
My concern with the loaded tires or wheel weights is I am going to be using this tractor on a rear mount finish mower and don't want any more weight than needed to rut things up. Was thinking about just making a 3pt hitch weight rack for ballast.
Are they hard starting in cold? My Kubota is about impossible to start in cold weather.
   / 1528 #4
Adding wieght on the 3 pt will be just fine, just as long as you use it when using the loader. The tractors are equipped with glow plugs. It never gets much below 10° F here and they start fine. Mnay folks in Canada won't buy a tractor with out a block heater, but it gets to -20º up there very regularly.
   / 1528
Will it handle a 72" finish mower without any problems?
   / 1528 #6
I have a MF 1445. The tractor has sat for at least a week or more out in the cold weather we have been having. We had wind chills to -25F below zero. I went out last week the night before the "big storm" we were going to get to put my blower on. My tractor has glow plugs. I cycled the glow plugs once and she fired right up. I let her smooth out a little and raised the throttle and walked away for awhile to let her warm up. I do not have a block heater on my tractor. I may install one this year just to have it plugged in and keep her warm and fuzzy feeling, :D . I have had my tractor for almost a year now, I bought it used, I believe its a 2004 or 05, and its never let me down. The best investment I have ever bought.
   / 1528 #7
I killed the battery twice trying to start my GC2310 in an attached unheated garage at about -25C. Original factory oil yet (~16 hrs). Got stuck slipping off the driveway into powdery snow, idled it with the lights on for a long time (digging out.....). Shut it down. Returned next day to start it, wouldn't fire. Booster cables from wife's car: fired right up.
I WILL be installing a block heater, and changing to Amsoil at the 50 hr service.
   / 1528 #8
No rpoblems here in cold weather, I have a 2006 1528gear, you will never have a problem with a 72" finish mower. this little tractor has some great power for its size. just make sure grass is dry, finish mowers don't like it wet stuff. :eek:
2014 John Deere 6105D (A50120)
2014 John Deere...
2015 JLG 6042 Telehandler (RIDE AND DRIVE) (A50774)
2015 JLG 6042...
1998 JCB 930 (A50120)
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
2000 International 4700 (A50120)
2000 International...
John Deere 7130 (A50120)
John Deere 7130...
