1528 smoking issue
   / 1528 smoking issue #1
double e
southern maryland
massey ferguson 1528
My 1528 is only a year old, but it has always blown ALOT of black smoke on start up even in the summer months. I called my dealer and he said that it was normal and to try starting with the throttle about a 1/4 open, this did not work. I exspect a little smoke, but when I start it in the garrage(a large 2 car with 14'ceilings it instanly fills it with black smoke. If this is normal than I can live with this, but if not I would definetly like to find the problem. Any ideals would be greatly appriciated.
   / 1528 smoking issue #2
The smoke is due to incomplete combustion until the glow plugs heat if so equipped.
Is that ok,or should I have it looked at.
   / 1528 smoking issue #4
Do u give the glow plugs time to heat before u try starting it. I've noticed they all smoke some on start up but not that bad.
   / 1528 smoking issue #5
My 1531 smokes real bad on startup hot or cold
Yes, usally hold the key for 7-14 sec depending on how cold it is, but in the garage it never gets below 40.
   / 1528 smoking issue #7
What are you using for fuel? Do you have a block heater? I would probably recommend heating the plugs a little longer. I know that my 1528 needs longer to warm up than some of my other tractors.
   / 1528 smoking issue #8
My 1532 is garage kept too, smokes bad on start-up like the rest of yours.
Using the block heater for 2 hrs will helps. You have to get ready to move it outside the garage and leave the doors open for a while.
My old BX 25 only puffs a little white smoke when cold starting in the winter.
Takes a while to get used to all of that black smoke, my dealer claims it is normal too? ( 55 hrs only on it)
   / 1528 smoking issue #9
I have a 1532 that I bought new a couple of months ago , and it does the same thing . I keep mine inside too . I usually hold glow plugs on a few seconds release and repeat a couple of times , my salesman said that is how he does his personal one . This is really the only concern of the tractor I have had . Not wishing you bad luck , but am glad to know someone else is experiencing this . I may contact MF hotline tommorrow , maybe if we all do this issue , might become important to them .
While, I don't like all the black smoke, it is a relief that it just may be normal for them and not actually something wrong.The smoke is not a big deal in the warmer seasons for I just leave the garage doors open for a while, but when it is 20* and the garage is heated and I have to open the doors :mad:. I guess I will have to put it in the lean to next winter when I am done building it :(
2005 EZ GO Textron Golf Cart (A53117)
2005 EZ GO Textron...
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
(3) BRUSH GUARDS FOR TRUCK (A51248)
(3) BRUSH GUARDS...
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
