Buying Advice 1500D
/ 1500D #1
tums20
Nor Cal
Kubota B6100
Looking at a 1500 D tractor with some implements
3 pt PTO Tiller, post hole digger, mower, and blade
Asking
$5300 for all or 3800 for just tractor
Really want a FEL, called Coldwater and her quoted 2200 delivered for the loader
Unit looks clean, think it is worth it? Missed on a 1510D earlier, someone went higher than I was willing due to the Yanmar 2 pt tiller
Any ways to tell if it is a VN import?
You have all been so helpful.
Thank You
/ 1500D #2
Ask questions about tractors history. Sounds like a fair price with the equipment if every thing is in good condition. :2cents:
/ 1500D
Went and saw it nice unit, 76 hours on hour meter so who knows where from, could not find serial number
Did not know what all the levers do so couldn't tell where 4wd lever was versus others, could not get my foot past brake to reach throttle so had to use hand throttle
Also, throttle would not stay at full, when pulled it full would slowly slide back to idle speed
Did start fast and seemed to run clean liked the 1510d better, but did seem powerful
/ 1500D #4
The 76 hrs is not likely. Could be 176, 276,976 or more.....anybody's guess. The price is fair with described attachments as long as everything is in working order. These are good little tractors......don't blame you for wanting the 1510d.....a little bigger is better. My 186d is the American sold version of the 1510d. Its been a good little machine.
/ 1500D
Is it an easy fix when the throttle will not stay at full? Always goes back to idle speed
Also I need to find some sort of diagram, no clue what all the levers did though the gears were in numbers.... no Japanese on it really at all besides a side plate which said 1500D and some other figures
/ 1500D #6
There's a rubber friction washer under where the throttle lever meets the dashboard. You can likely adjust the tension on it, or maybe $5 for a new friction washer. No big deal.
/ 1500D #7
Check out Hoye Tractor......they have lots of info on the 1500.....including manuals.
YM1500_1500D: Yanmar Tractor Parts
/ 1500D
There is also a 155d in the area, similar size? Any recommendation between the two?
/ 1500D #10
The friction washer is like $1-2 at Hoye and is an easy fix. If thats all you found thats not even an issue.
76 hours is not real. It will have more than that on it. Could be a recon or just that it was rolled over soon (the hour meter not the tractor)
Manure Spreader (A65640)
Manure Spreader...
20ft. x 8ft. Shipping Container (A65640)
20ft. x 8ft...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
Cute Electric Car (A62679)
Cute Electric Car...
43018CFL (A59228)
43018CFL (A59228)
