1500D PTO
/ 1500D PTO #1
reb
Central Arizona
YM1500D
I gather from reading the parts manual that my 1500 has a 3-speed PTO. However, I have been able to engage only one speed, with the lever pushed down and (I think) back. Am I missing something or is there a problem somewhere?
Thanx.
/ 1500D PTO #2
Reb,
Your pto lever should be on the lower left hand side of your operating area, and your fwd lever is also on the left side. The pto control is the one closest to your fender, and should have five positions....all the way down toward the floor area is 540.....click up....neutral....up again....760....up again...neutral...up again....1000. You will use 540 most of the time for american implements. I'm certain that there is a neutral between 540 and 760....and mostly sure that there is a neutral between 760 and 1000.
/ 1500D PTO #3
I have a Y1500 not the D but my PTO lever is on the left also. There are 3 speeds, 1 is back ( I use this with my bush hog) 2 is forward ( I don't use this) 3 is down and forward( I use this with my RS1200 tiller). I may have the direction of 1 and 2 backwards but they are definately in the same plane.
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2018 - Tier 4 Interim (A63689)
Kubota...
2017 Infiniti QX50 SUV (A61574)
2017 Infiniti QX50...
KMC 4R ROLLING CULTIVATOR (A63291)
KMC 4R ROLLING...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
