1500d ingnition
/ 1500d ingnition #1
cam0148
Penticton, BC Canada
Cub Cadet EX3200
Hey gang,
I need to get a replacement ignition for my 1500d. Does anyone know if there is a JD part that would do the job?
Thanks,
Jeff
/ 1500d ingnition
Hey gang,
Thanks,
Jeff
/ 1500d ingnition #3
Uh...since these are Diesels, I assume you mean the key switch?
Any of the dealers listed here or who post here should be able to helkp you with that. I bought mine from Hoye............
/ 1500d ingnition #4
/ 1500d ingnition #5
I bought a key switch from Hoye as well. Esaies way to locate the switch is to do an (ignition) search on their main page.
/ 1500d ingnition #6
/ 1500d ingnition #7
I bought a spare key for my 155d from a john deere dealer. I got two for under 6 bucks same key other than the deere one it. I just took the key i had to them and they matched it up. So maybe they have ingnition to.
/ 1500d ingnition #8
/ 1500d ingnition #9
You could use a good (heavy) 7/8" universal ignition switch from any auto parts store. You'll want a four position switch if you use the thermo-start.
/ 1500d ingnition #10
/ 1500d ingnition #11
The univeral switch makes sense to me. My 1500D uses a separate switch for the thermostart, so a four-posititon switch would not be required, though.
/ 1500d ingnition #12
/ 1500d ingnition #13
Installed a universal switch on my 1500 last year and it works fine.
/ 1500d ingnition #14
/ 1500d ingnition #15
Sure, you could do that............
But why not put it back the way Yanmar intended it? I don't think there's much difference in price to have an actual Yanmar switch with the thermostart built in...............and they're easy to come by, just contact Hoye or any of the dealers who post here, I'll bet any of them can supply you with the right switch, and quickly.
/ 1500d ingnition #16
/ 1500d ingnition #19
Thermostart was an option on most "00" models as I understand it, and it is not uncommon to see 1500s without it, as well as 1500s with a pushbutton that activates the thermostart.
/ 1500d ingnition #20
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2007 Jeep Commander (A62613)
2007 Jeep...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
