1500D head gasket
/ 1500D head gasket #1
damammel
Sterling Ct
Yanmar 1500D
Morning all. Just looking for any advice on replacing the head gasket in my 1500D. I started getting coolant in the oil the other day. It seems that a stud may have loosened in the cold weather. The head is off and I have checked it with a straight edge. It checked out straight. At this point I'm thinking I'll replaced the gasket and run it. Any thoughts on sealing the stud threads before reinstalling them? Thanks for any thoughts.
/ 1500D head gasket #4
May want to consider new studs/bolts. Esp. if it happens again.
/ 1500D head gasket
Has anyone gone back to retorque the head after running it for a while. Friend of mine suggested it but I don't see the need. Plus doing that means doing a valve adjustment again since there's not enough room for a socket with the rocker assemblies on the head.
/ 1500D head gasket #7
I don't retorque for the reason you gave.
/ 1500D head gasket
Thanks again Winston. Hope to have it up and running today. Going to see how it likes running a chipper. It's a bit underpowered but only doing mostly pine.
/ 1500D head gasket #9
I think its a good idea. Maybe 50 hours after a head gasket then every 10 years/1,000 hours.
I did a major checkover on my YM240 (YM2000) after several years and found uneven valve clearance. Checking further, there was one head bolt that went a half turn before it met spec that might account for this. Neither of these had caused any other problem but it seems like they could eventually.
/ 1500D head gasket
I think its a good idea. Maybe 50 hours after a head gasket then every 10 years/1,000 hours. I did a major checkover on my YM240 (YM2000) after several years and found uneven valve clearance. Checking further, there was one head bolt that went a half turn before it met spec that might account for this. Neither of these had caused any other problem but it seems like they could eventually.
That's a good suggestion. I think that would be a smart thing to do in the future. I would not mind checking them before adjusting the valves every year. I have never adjusted the valves before this point. I probably should of. They were a bit tight.
/ 1500D head gasket #11
I had a similar problem on my YM1500 and the culprit was the engine or sleeve O-ring on one cylinder allowing the coolant into the oil. I replaced the head gasket, but my old one looked OK. Maybe I had it explained to me wrong, but I haven't had any problems since replacing the O-Rings.
John Deere Planter (A62613)
John Deere Planter...
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
2002 Built Rite Trailer (A66285)
2002 Built Rite...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
429860 (A61166)
429860 (A61166)
SILVER EAGLE CST20W 5TH WHEEL DOLLY (A64277)
SILVER EAGLE...
