1500D Front drive grease fittings
   / 1500D Front drive grease fittings #1
glgdiggs
VA by the bay
Landtrac 360 TLB,2 Landtrac 530DTC
What are the grease fittings for on the upper gear case and lower knucle portions of the front axle assembly, I thought the bevel gears, shafts and axles were lubricated by gear lube.
   / 1500D Front drive grease fittings #2
I think those are actually supposed to be plugs. I have had a few customers tell me that their tractors came with grease fittings there too. I think someone just put them in there because they lost the plug and they fit- or else to make lubricating easier. You do not want to use grease in there though. Use 90wt gear lube.
Aaron
Parts@hoyeTractor.com
(940)438-0386
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2021 JOHN DEERE 8R 370 LOT IDENTIFIER 175 (A53084)
2021 JOHN DEERE 8R...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED FUTURE FT-XGJ 40" HYD ROTARY TILLER (A51248)
UNUSED FUTURE...
