1500D Front drive grease fittings
   / 1500D Front drive grease fittings #1
glgdiggs
VA by the bay
Landtrac 360 TLB,2 Landtrac 530DTC
What are the grease fittings for on the upper gear case and lower knucle portions of the front axle assembly, I thought the bevel gears, shafts and axles were lubricated by gear lube.
   / 1500D Front drive grease fittings #2
I think those are actually supposed to be plugs. I have had a few customers tell me that their tractors came with grease fittings there too. I think someone just put them in there because they lost the plug and they fit- or else to make lubricating easier. You do not want to use grease in there though. Use 90wt gear lube.
Aaron
Parts@hoyeTractor.com
(940)438-0386
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2025 JOHN DEERE 408R LOT IDENTIFIER 10 (A53084)
2025 JOHN DEERE...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
