1500D Front drive grease fittings
   / 1500D Front drive grease fittings #1
glgdiggs
VA by the bay
Landtrac 360 TLB,2 Landtrac 530DTC
What are the grease fittings for on the upper gear case and lower knucle portions of the front axle assembly, I thought the bevel gears, shafts and axles were lubricated by gear lube.
   / 1500D Front drive grease fittings #2
I think those are actually supposed to be plugs. I have had a few customers tell me that their tractors came with grease fittings there too. I think someone just put them in there because they lost the plug and they fit- or else to make lubricating easier. You do not want to use grease in there though. Use 90wt gear lube.
Aaron
Parts@hoyeTractor.com
(940)438-0386
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
