1500d driveshaft question
/ 1500d driveshaft question #1
cam0148
Penticton, BC Canada
Cub Cadet EX3200
Has anyone ever made or had made a universal joint style drive shaft for a 1500d.
I am having nothing but issues with my, keeps loosing the 4wd, because the steel balls keep falling out of place.
Therefor I was thinking that a ujoint might be a better solution.
Thanks,
Jeff
/ 1500d driveshaft question #2
I've never done it, but it sure seems like it should work. My YM1110D and YM1301D both use universal joints on the front drive shaft. So does the YM1510D.
I dont suppose you could take a pic of the u joint to show me.
It would be helpfull to show a machinest what I really want done.
Thanks,
Jeff
/ 1500d driveshaft question #4
If you do put in universal joints , you'll also have to allow for a change in length. Before you go to all the work to do this you may want to replace the spring. I've come across a couple YM1500ds with this problem & the spring was not strong enough.
Thanks for the advice on the spring. I have already replaced it and the spring did not help.
When I look at the pinion in the front axel one of the groves is worn more then the others, which I beleive is the cause of the slippage.
1999 Volvo Sleeper (A62613)
1999 Volvo Sleeper...
2004 International 8600 Tender Truck (A63688)
2004 International...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
John Deere Z997R (A60462)
John Deere Z997R...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
