1500 Radiator Overflow Tank
   / 1500 Radiator Overflow Tank #1
R Barger
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV X900 Mahindra 4540 4WD w/Loader
I just purchased a 1500. It doesn't have a overflow tank for the radiator and I don't think it has ever had one. When I fill the radiator up completely it puts coolant out the the overflow for a short period and then stops. Should I add a tank or not? ford 1500.jpg
Well I'm responding to my own post. I thought there would be a 1500 owner respond and at least tell me if a 1500 has an overflow tank or If I should add one. This tractor is all original with the overflow tube is running beside the radiator all the way to the bottom.
I don't think they had a tank, but you can check the parts lists and diagrams here: New Holland Parts | Messick's
Thanks for the reply. The parts list doesn't show a tank so I suppose It will put coolant out till it has enough room in the radiator for expansion.
   / 1500 Radiator Overflow Tank #5
We had a Ford 1100. It didn't have a coolant recovery tank. It just belched out the extra through the tube onto the ground until there was enough room in the radiator.
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
49205 (A55788)
49205 (A55788)
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
PumpJack Brand Pump Jack (A56435)
PumpJack Brand...
1998 PETERBILT 377 (A58214)
1998 PETERBILT 377...
