1500 Radiator Overflow Tank
   / 1500 Radiator Overflow Tank #1
R Barger
Gold Member
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV X900 Mahindra 4540 4WD w/Loader
I just purchased a 1500. It doesn't have a overflow tank for the radiator and I don't think it has ever had one. When I fill the radiator up completely it puts coolant out the the overflow for a short period and then stops. Should I add a tank or not? ford 1500.jpg
Well I'm responding to my own post. I thought there would be a 1500 owner respond and at least tell me if a 1500 has an overflow tank or If I should add one. This tractor is all original with the overflow tube is running beside the radiator all the way to the bottom.
I don't think they had a tank, but you can check the parts lists and diagrams here: New Holland Parts | Messick's
Thanks for the reply. The parts list doesn't show a tank so I suppose It will put coolant out till it has enough room in the radiator for expansion.
   / 1500 Radiator Overflow Tank #5
We had a Ford 1100. It didn't have a coolant recovery tank. It just belched out the extra through the tube onto the ground until there was enough room in the radiator.
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
man basket 72 '' (A56857)
man basket 72 ''...
33ft Dovetail Flatbed Trailer (A55315)
33ft Dovetail...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2016 Case CX55B (A55973)
2016 Case CX55B...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
