1500 Fuse Block
/ 1500 Fuse Block #1
joebob
Manchester MI.
Case 530CK
Anyone replaced the fuse block on a 1500d or similar? If so, what'd you use? Do you think there is one I can get at Napa? The one on the tractor doesn't look so great these days. It seems pretty crude, the "fuses" are more like open filaments and if it blows I probably would't know where to get any.
/ 1500 Fuse Block #2
Not sure whether napa sells a generic fus block or not.. but you couls always take a trip to a junk yard, and pull one outta a junker.. just root around and find something you like.
Soundguy
/ 1500 Fuse Block #3
Yes NAPA does. I put one in a 6x6 ATV I had. If NAPA's doesn't work for you, Radio Shack also has some.
/ 1500 Fuse Block #4
I used a fuse block that I got from NAPA to replace the one on my YM1700. Unfortunately, I did not keep a record of the part number. I have attached a pic that shows how it looks. The mounting holes were the same as the old. The only change I had to make was to grind off one corner (visible in pic).
/ 1500 Fuse Block #6
There are six fuses on the block, but only 4 are used. If you look closely, you will see wires connected to 4 terminals. I had some old fuses that I used on the right side, which are not as colorful as the ones on the left side.
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
Columbo Peanut Inverter Blades & Coulters (A64119)
Columbo Peanut...
2853 (A64281)
2853 (A64281)
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2004 Dodge Ram...
