15 series headlight?
/ 15 series headlight? #1
Oldnbusted
Branson 4215R, Hinomoto E2304, Ferguson TO30, Hustler Raptor SD60
Driveway flooded Monday night, had to get the 4215 out before daylight Tuesday to move a tree that washed across the driveway. That’s when I discovered that the headlights on these things are woefully inadequate for anything other than lighting up the inside of the barn.
I read on here somewhere that the 10 series uses a standard H4 bulb. Anyone know if the 15 series is the same.
Ordered a light bar to hang under the rops and a couple of 5” floods for the fenders, but I’d also like to upgrade the stock bulbs.
TIA
/ 15 series headlight? #2
It should be H4 as well. The other problem with these lights is that they point waaay too high. There is an adjuster on those but won't make much difference.
I have a F36Rn which is the equivalente of the 3515R. Here is the before and after. I added two small 18W light bar to work in conjunction with the OEM lights. Even though those were small light bars it still makes a lot of difference.
That is a huge difference! Thank you.
I’ll likely replace the stock bulbs with leds, but the FEL will always be an issue. That’s why I’m thinking fender mounts.
/ 15 series headlight? #4
On the rare occasion I use the tractor at night, the brush guard blocks much of the beam, and THEN I have the big round bale in front of that blocking the rest...
I've been planning to put a light bar on the ROPS for years, but just haven't gotten to it yet.
2012 FORD F-550 CAB AND CHASSIS (A67714)
2012 FORD F-550...
2010 CHEVROLET TAHOE SUV (A66091)
2010 CHEVROLET...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
JOHN DEERE 6420 TRACTOR (A65054)
JOHN DEERE 6420...
