15 foot Howse cutter
/ 15 foot Howse cutter #1
strawberry
WHITE PLAINS, KY
1586 INTERNATIONAL
Looking at an older model Howse batwing cutter. Does anyone have any experience with this cutter? It is older, heavier constructed machine.
/ 15 foot Howse cutter #2
Not the batwing, but my cousin had a 5' and currently has a 6' Howse. And, we both have a 6' Howse finish mower. The older Howse stuff seems to be solid, almost over-built.
As with any used cutter, the most important components are the gear boxes. I would caution you that the "splitter" box for just about any flex-wing cutter will cost several thousand dollars to replace. Perhaps even more than you paid for the cutter. :( Also remember that you could be looking at a few hundred $$ just to replace the blades and bolts. And, all of those U-joints and driveshafts take a beating on a flex-wing when mowing uneven ground.
Not trying to discourage you, just wanting to give you a realistic picture. :thumbsup:
2023 John Deere Z960M Zero Turn (A63116)
2023 John Deere...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63118)
2021 Unverferth...
Wooden Wagon Wheel Bench (A61569)
Wooden Wagon Wheel...
John Deere 1023E (A62177)
John Deere 1023E...
SKYJACK SJ86T TELESCOPIC BOOM LIFT (A62129)
SKYJACK SJ86T...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
