1440v loader hyd.
   / 1440v loader hyd.
Thanks Jerry....Ive been working the last few days and havent had a chance to check it out...going to try to this weekend... thanks again Bruce
   / 1440v loader hyd. #12
If you need anything else let me know, I have all of the manuals for the tractor, loader and backhoe (1475), parts and shop.
   / 1440v loader hyd.
Thanks for all the help ... I had to order a pressure gauge .. is one that goes from 0 to 2000 p.s.i ok ?? never had to do this, so this is all new to me... thanks Bruce
   / 1440v loader hyd. #14
You need a 0-2500 or a 0-3000 gauge. The system pressure is set at 2130 psi.
   / 1440v loader hyd.
Hi Jerry...I got my gage today...after i put it on do i just start the tractor and let it idel and read it ??? this is a first for me thank you for the help Bruce
   / 1440v loader hyd. #16
hernando,
It needs to be checked at 2600 RPM. I don't know if you are checking at at remote or at the pump. If you check at the pump the pressure should be 2276 PSI. If it is at a remote it looks like it should be 2130 PSI.
   / 1440v loader hyd.
Hi Jerry...Sorry to trouble you again.. i finaly got to check my pressure....i must be doing something wrong..it is the pipe coming out the top of the pump..? or am i wrong ? i put the gauge on it at 2600 r.p.m it onley shows about 250 to 500 lbs.. if i cycle the loader it gos to 1000 psi..am i doing somthing wrong ? thanks for all the help ..bruce
   / 1440v loader hyd. #18
Know problem. Where the pressure pipe comes off of the pump, there is a 1/8" pipe plug in the end of the pipe. That is the best place to pick up the pressure.
   / 1440v loader hyd.
I thought i had it in the right place ...the plug i took out is at the end of a pipe that is held in place by three bolts on the top of the pump ....is this the right place ?? sorry to be so much trouble ...thanks
   / 1440v loader hyd. #20
That sounds like the right place. Is that where you got the low readings?
UNUSED FUTURE MINI EXCAVATOR HYD HEDGE TRIMMER (A51244)
UNUSED FUTURE MINI...
2015 CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
