1401 front wheel wobble
/ 1401 front wheel wobble #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
My YM 1401 (2wd) front wheels wobble when the tractor is in high gear. I have done about all the adjustments I can do. What is the recommended fix?
Thanks for the help.
I have tightened the front bearings.
/ 1401 front wheel wobble #5
I have a 1401 D (4wd) that has some wobble if not in 4wd because the key slot for the steering arm is very worn (looking for a new arm by the way)
not sure if the 2wd has a similar key slot?
/ 1401 front wheel wobble #6
The part no. for your 1401D's steering arms are the same as for the YM155 (2 wheel drive). They made a lot of the YM155's, should be easy to find the steering arms.
/ 1401 front wheel wobble #8
if the bearing checks out OK, Look into the camber alignment being out, turn the wheels as much to straight forward as you can, measure between the front tires at front and then at rear of tires, should be close to the same measurement,
although if the camber is off enough to make them wobble, you should be able to pick up the difference visually,
also might check the center pivot pin, the pin that the front axle rest on could be severely worn and in need of replacing
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
ASSET DESCRIPTIONS & CONDITION (A59914)
ASSET DESCRIPTIONS...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
Coleman Minibike (A65579)
Coleman Minibike...
