Oil & Fuel 135 Fuel Lift Pump Question
   / 135 Fuel Lift Pump Question #1
cracker11
I am trying to replace the fuel lift pump in my '71 135 diesel, but the fuel lines will not come out of the pump. There seems to be a hard rubber seal around the end of the lines. What is the trick I am missing? Do I need to hand a dead chicken over my shop door? Thanks for any help on this one.
   / 135 Fuel Lift Pump Question #2
G'day cracker just give them a good pull they will come out make sure you fit new ones with the pump as they will most likely leak. Good luck
Jon
Thanks Jon. I'll pull a bit harder. Duane
   / 135 Fuel Lift Pump Question #4
there are rubber ferrules on the lines. they have gotten hard as a rock over time and they are expanded into the threads where the line nuts thread into the pump. the lines are very tough to get out of the pump. you have no choice but to put enough pressure on them to remove em. the new ferrules will look much smaller and will be much softer. you might take a small sharp scribe or probe and stick it in the port beside the lines in several places and try to crack em around the line. good luck
   / 135 Fuel Lift Pump Question #5
I know exactly what you mean, I had to clean the fuel limp pump on my MF 175 in the autumn, As I was not replacing them I had a hard time to get it back in. If I recall correctly simultaneously pushed them in as I put the pump back, not doing them steps on at a time. But with new rubber it will probably be easier.
   / 135 Fuel Lift Pump Question #6
have a 135 mf. 3cylinder diesel perkins.had fuel pump rebuilt.i am still having a slight pause at1300 rpm.all new filters
tank is clean fuel flows free.when in high 1 going up driveway at 800 rpm i pull to wide open an it it slowly starts to
excel.til it hits 1500rpm then jumps up fast is it my lift pump.it is a 2 bolt pump.
   / 135 Fuel Lift Pump Question #7
G,Day harold 8353.
I would say that it is more likely the injector pump that is the problem ,was the PAUSE there before the overhaul???.
To check the fuel lift pump remove the fuel line that goes from the secondary fuel filter to the rear connection on the injector pump and get someone to operate the lift pump hand primer you should get a good strong flow every stroke of the lift pump lever ,if not check the fuel filters first, if all is good with the fuel SUPPLY I would remove the injector pump and have it Bench tested .
Happy Days .
Hutch.
   / 135 Fuel Lift Pump Question #8
Upon reassembly, you will need to replace the neoprene seals, which are available at your MF dealer. These are called "olives" in the parts diagrams.
Dean
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2003 Ford F-150...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
2021 Bell TC-11A Crawler Carrier Dump (A52384)
2021 Bell TC-11A...
