1330 PTO question
/ 1330 PTO question #1
chewy66
Can anyone tell me what would make my blades turn themselves off while mowing. Sometimes it will happen several times within a five minute period and then other times it only does once or twice. In each case all I have to do is re-engage the PTO by flipping the PTO switch. After going through this little cycle it will then stay on until I flip the PTO off when finished mowing. I have checked the belt for proper alignment and wear and both are OK. I am concerned that there is a bigger problem and every time I re-engage the PTO it is doing more damage. Thanks for any help.
/ 1330 PTO question #2
I'm not familiar with that model but most Cubs have a reverse cutout for the PTO and a seat actuated PTO cutoff.
Is it happening when you back up or are you mowing on some bumpy turf?
If not it could be a poor electrical connection in the PTO circuit, a corroded fuseholder or PTO clutch adjustment.
Curt
/ 1330 PTO question #3
You might also check to make sure your ground wire is making a good connection and hasn't corroded or come loose from it's frame and battery connections. Most of the "safety cut-off switches" run on the grounding circuit on the mowers I have worked on in the past.
The switches that are seat and pedal actuated usually have a little "piston" that is depressed or released to activate the switch. Sometimes they get dirty and cruddy. Just spray some "electrical cleaner" - NOT WD 40, unless that is all you have 'cause it is residual and will collect more crud - around the piston area and on the contacts. It will evaporate quickly and should help to free it up if it is sticking.
Using a little "dielectric grease" on the connections and will help keep them clean of debris. Works great on the spark plug's threads and boot also.
/ 1330 PTO question
Thanks for the replys. I mowed today and it only did it twice. I do believe it is a wire issue though because when it happened the second time today I barely touch the toggle switch and the blades re-engaged. Thanks again for the help
2022 EZ-GO ELITE...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
