1320 won't start
/ 1320 won't start #1
Rickps
1320 won\'t start
I am having problems starting my 1320 the battery is fully charged and I don't have any power at the ignition switch
/ 1320 won't start #2
Re: 1320 won\'t start
Check for 12 volts at the starter terminal to ensure that the battery cable is good. There should be a smaller wire going from the starter terminal up to the ignition switch. Perhaps it is loose or broken. I'm not sure if there are any fuses in the circuit but I would test any fuses you can see.
Bob B.
/ 1320 won't start
Thanks Bob for your help I'll have to check that wire tomorrow
/ 1320 won't start #4
There's a 20A fuse under the seat that you might want to check. I've had to change mine once or twice.
203201 (A60429)
203201 (A60429)
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
(3) Corral Gates (A66408)
(3) Corral Gates...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2018 JOHN DEERE 60G EXCAVATOR (A64277)
2018 JOHN DEERE...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
