1320 won't start
/ 1320 won't start #1
Rickps
1320 won\'t start
I am having problems starting my 1320 the battery is fully charged and I don't have any power at the ignition switch
/ 1320 won't start #2
Re: 1320 won\'t start
Check for 12 volts at the starter terminal to ensure that the battery cable is good. There should be a smaller wire going from the starter terminal up to the ignition switch. Perhaps it is loose or broken. I'm not sure if there are any fuses in the circuit but I would test any fuses you can see.
Bob B.
/ 1320 won't start
Thanks Bob for your help I'll have to check that wire tomorrow
/ 1320 won't start #4
There's a 20A fuse under the seat that you might want to check. I've had to change mine once or twice.
