1320 remote hydraulics
   / 1320 remote hydraulics #1
6sunset6
Veteran Member
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have a 1320 HST 1992 bought it in 96 and now have 400hrs on it. Mostly FEL landscape work. It has turf tires and is slightly underpowered for my long long driveway when it snows. I snow blow down the middle and some tight spots and then plow. I have a single remote valve in the rear I use for to angle the plow which is on a QA. I just converted the manual chute rotation on the snow blower to hydraulic. I was going to put a diverter valve after the disconnects in the rear but now I am wondering if there is a way to stack another valve on the remote that is there. I noticed the TC 31DA has an option for 2 remotes. ( have to figuire out how to justify a trade in) Is there an aftermarket supply for remotes?
Any body have any experience with a tractor this old? joke.
   / 1320 remote hydraulics #2
Welcome to tbn,
yes - you can do aftermarket remotes - they usually plumb into the loader power beyond port. The valve(s) are "ugly" compared to the factory ones on a TC31DA - usually U bolted to the ROPs. Graba cold one & do a search on hyrdaulics or rear remote or top and tilt for more details, pix etc.
PS - more HP never hurt ethier - I'm in the process of upgrading my TC18 to a 30HP - likely Kubota B3030.
2013 Mack GU713 T/A A-Frame Gin Pole Truck (A60460)
2013 Mack GU713...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2020 DRAGON ESP...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
DEUTZ MARATHON...
