1320 buying advice
   / 1320 buying advice #1
smwelch
cub cadet 1320 made in 1991 working condition 400 dollars I have 2 acre yard to mow. Is this a good purchase or is this going to be one nagging problem after another. My other option is to buy a new cheap tractor at sears for a little over a thousand. My yard is flat with no real obstacles. I want the cub cadet but im apprehensive about having a machine that is going to need to be fixed all the time
   / 1320 buying advice #2
I've owned, and still do, a 1320 Hydro. No problems.
Mowing 1 1/2 acre, does a nice job.
   / 1320 buying advice #3
This is a lawn tractor so if you can i would try to find a little history on it.What kind of lawn did it mow flat or hilly.With a garden tractor this would not bother me that much but i think it is important with a lawn tractor.was it used for snow removal? the snow blades can be hard on them.What kind of condition is it in?If it is clean and not all beat up a good chance who had it before took good care of it.Make sure you give it a test drive if there is a hill near by drive up it see how it reacts.When you start it make sure who has it didn't let it warm up before you got there.It will probably smoke a little on start up but if it clears up fairly quick i wouldn't worry.Look for the normal stuff like oil leaks and so on.Now this mower is over 20 years so there is a good chance you will need to stick some money into it sooner or later.Hopefully later.
If it were me i would look for a garden tractor.Because when you put some money into it, for example a starter you still have a machine with a heavy duty hydro front end and so on.Tankman has had great luck with his 1320 with anthing used it is a roll of the dice.
Sears...I think craftsman makes a ok lawn tractor but not sure how good and how long a $1000 one will last? if you buy new and if you can i would raise the budget.I think you will be a lot happier and money a head.
Also if you buy new i would buy from a dealer not box store.IMO this is important.I would look at john deere they have great customer service.Cub Cadet "dealer" that would be a good start also.
Good Luck and check back in on what you do
   / 1320 buying advice #4
Still fond of my early tractor days, '32 Farmall (1st year with rubber tires), then many old Wheelhorse garden tractors.
Wheelhorse is now Toro and, I don't think (don't know) if they're as rugged as they once were.
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Push Mower (A55973)
Push Mower (A55973)
