Nov 5, 2007 / 1300D Cooling system #1 O Orlando New member Joined Apr 17, 2007 Messages 6 Hi, I have a YM1300D, (155D) and a need to change the water in the cooling system, the question, is how to do it?? I have a manual, and it only says that takes 4.9 Litres !!! What should i do first ? Best Regards Orlando Ferreira
Nov 5, 2007 / 1300D Cooling system #2 K kenmac Super Member Joined Feb 13, 2005 Messages 9,835 Location The Heart of Dixie Tractor McCormick CX105 Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4 I pull the bottom rad. hose when I change. Be careful if you do this while the system is hot
Nov 6, 2007 / 1300D Cooling system Thread Starter #3 OP O Orlando New member Joined Apr 17, 2007 Messages 6 thanks But a need to know if i only take the old water out, a fill with new one? Do i need to make samthing else?
Nov 6, 2007 / 1300D Cooling system #4 N NTEXSAM Member Joined Jul 9, 2007 Messages 33 Location NORTH TEXAS THE COOLING SYSTEM HOLDS 0.8 GALLONS. YOU SHOULD RUN A 75%WATER 25% ANTI-FREEZE MIXTURE,UNLESS YOU ARE IN A COLD WEATHER CLIMATE SAM
Nov 7, 2007 / 1300D Cooling system Thread Starter #5 OP O Orlando New member Joined Apr 17, 2007 Messages 6 Can i also clean the radiator with water before refull with the mixture? Is it necessary to bleed the circuit? and how to do that? Thanks
